hello
the app works great also the ptz cam control
but where is the switch/button for cam home position?
I can not find it, where can I activate it?
on zm webinterface the home button works great!
zmninja ptz home position button
Re: zmninja ptz home position button
If you have a home preset set for that camera, you should see a "home" icon in the PTZ buttons - note that the PTZ set is scrollable so please make sure its not hidden (the PTZ buttons are displayed when you enable them from the floating menu button)
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
thanks
I do not have the upper switches also not when I scroll
how can I activate it?
sorry i again
i found it
i forgot to activate the preset tab check HAS PRESETS and check HAS HOME PRESET
now it's working
thanks again your the man
i found it
now it's working
