Api not work after upgrade to 1.31.1
Cippalippa
Post by Cippalippa »
After upgrading to version 1.31.1 zmninja does not connect by giving a bug of API not found, can you help me? thank you
Ubuntu 14.04.05 :D
Screenshot server-ip/zm/api
Re: Api not work after upgrade to 1.31.1
there was a thread just last week concerning this...some components for the API may not have been included in the build of the ZM package you used.
Cippalippa
do you think in the next releases will restore this feature?
yes it will be. the app zmNinja is a very good and popular interface for example, which is dependent on the API as well as many other custom made programs. There is a way to fix it in this version as well...I think there is a thread on this subject floating around recently. This version 1.31.1 is not a stable release! The version is very close to the cutting edge with that distinction going to StorageAreas version 1.31.9 from the iconner PPA.
https://forums.zoneminder.com/viewtopi ... 21#p102921
Cippalippa
Ok i have upgrade to 1.31.3 version and api works fine, thanks
