For those of you on 1.30.x who doubly use your DVR for both security, and posting an image up to Weatherunderground (all... 2 of you?) This script should be a little handy. I added it to my crontab to run every 5 minutes. The reason I used this script instead of pulling a JPEG from the zoneminder URL, is that I use a very low compression quality on streaming (but highest quality for saving files). I want to send WU the best quality I can, so I pull straight from zonminder's capture buffer. Hope it helps!
You will need to change the USER, PASSWORD, IMAGEFILE NAME (monitor number #), the ZMU command to select your monitor number #, and ADMIN Folder. You will also need to install jpegoptim (sudo apt-get install jpegoptim) so that your file sizes are pretty small.
FTP Upload Script (also includes the appending for timelapse)
#! /bin/sh
#Setting up variables
REMOTE='webcam.wunderground.com'
USER='YOURUSERNAME'
PASSWORD='YOURPASSWORD'
FTPLOG='/tmp/ftplog'
IMAGEFILE='/var/www/html/Monitor#.jpg'
TIMELAPSEDIR='/dvr/wxcam/'
date >> $FTPLOG
#Capture image to the HTML folder, and then compress it
cd /var/www/html/
zmu -m 7 -U viewer -P viewer -i -v
sleep 2
jpegoptim --size=50k $IMAGEFILE
#Upload file to FTP server
ftp -n -v -p $REMOTE <<_FTP>>$FTPLOG
user $USER $PASSWORD
quit
_FTP
#Append Image file to timelaspe video (Comment this out if you are not using it)
cat $IMAGEFILE >> $TIMELAPSEDIR/`date +"%Y%m%d"`.mpg
#Move image file to web directory (For other non FTP places to grab it?)
mv $IMAGEFILE /var/www/html/wxcam.jpg
exit 0
Credit where credit is due: clipo suggested it on this post: viewtopic.php?t=15198
For timelapse videos, I concatinate JPGs into an MPG file, then convert that at the end of the day. Here is that end of the day script:
#! /bin/sh
#Setting Up Variables
TIMELAPSEDIR="/dvr/wxcam"
FILENAME=$(date +"%Y%m%d")
cd $TIMELAPSEDIR
echo $TIMELAPSEDIR/$FILENAME.mpg
#Delete files older than two weeks
find $TIMELAPSEDIR* -mtime +14 -exec rm -f {} \;
#Convert file to make happy and small then delete the original
ffmpeg -y -i $TIMELAPSEDIR/$FILENAME.mpg -r 30 $TIMELAPSEDIR/$FILENAME.mp4
rm -f $TIMELAPSEDIR/$FILENAME.mpg
