Page 1 of 1
Camera Control - Wanscam HW0036
Posted: Sun Oct 29, 2017 8:20 am
by Bosquetia
Dear All,
Newbie on zoneminder... running on a VM Debian 9.2.1, hosted on Esxi 6.5
Everything is OK :D
But (always a 'but')
I am not able to control my cams.
In the control tab, I'm not sure what to set exactly.
Address : I put a cam ip. Do I need to put the port as well like 192.168.1.10:81 or only IP
Type I select wanscam HW0025 but I edit it before as my cam are working that way :
For move up : /decoder_control.cgi?command=0&onestep=0&user=#username#&pwd=#password#
I've discovered this viewtopic.php?f=29&t=21198&p=80309&hili ... rol#p80309
So I modify like that but still don't work :-(
Don't know where to check now... So if one of you can help. Will be much appreciated
Cheers
Re: Camera Control - Wanscam HW0036
Posted: Sun Oct 29, 2017 11:53 pm
by vskatusa
I have a old panasonic ptz camera and here are my settings. Not sure weather you need to tweek these:
controllable: checked
control type: panasonic IP
control address: {username:password}@{ip:port}
others are all default values.
HTH
Posted: Mon Oct 30, 2017 10:21 am
by Bosquetia
I'll try this in the control tab... (if I am lucky, the perl script will be able to move my cam :-) )
Posted: Thu Nov 02, 2017 5:50 am
by Bosquetia
Hi again,
I tried again and again without success.
So if one of you have a way to fix this, this wll be great
Posted: Sat Apr 21, 2018 9:03 pm
by Rapheal
Did you ever get this resolved?
