No video after enabling OPT_USE_AUTH
Demonicpenguin
Post by Demonicpenguin »
I enabled OPT_USE_AUTH and I am no longer able to view video on the monitor I setup.
I have tried changing the restricted setting, logging in and out, making a new account, rebooting ZoneMinder, rebooting the whole server. If I disable OPT_USE_AUTH it works just fine and I am able to see it no problem.
Anyone have some insight as to why this might happen?
Demonicpenguin
Re: No video after enabling OPT_USE_AUTH
Turning AUTH_RELAY to none fixes this issue.
I had this issue over and over again until v 130.+ although it can still appear there. I am not really sure what the causes the "Hashed" option to not actually create the correct hash to authorize. I use ZM streams embedded into web pages and this will occur unless "None" is selected because I do not generate an actual authorization hash.
