I can't add a cameras
Nesti
Post by Nesti »
Hi, my language not is English, I'm sorry by this.
I'm new in this forum and it's the first time I'm use this software.
I have a problem, I have installed zoneminder in a clean version of ubuntu server 16.04 and it seems to work, but when I go to adding a camera doesn't work, the log file informs to me of several errors and I don't know how to solve it.
Can someone help to me?
I upload a picture of the log file
The version of ZM
when I'm trying see the camera
Thanks u and best regards
digital-gnome
Re: I can't add a cameras
Post by digital-gnome »
Try using ffmpeg as your source instead of remote.
What camera are you using? What install instructions did you use?
Nesti
Post by Nesti »
digital-gnome wrote: Wed Nov 29, 2017 9:04 pm Try using ffmpeg as your source instead of remote.
Hi, I have done what you have indicated to me, this is what the log file indicates
but this no work :'(
bbunge wrote: Wed Nov 29, 2017 9:57 pm What camera are you using?
Dlink DCS2121
bbunge wrote: Wed Nov 29, 2017 9:57 pmWhat install instructions did you use?
I used the instructions on the official website
http://zoneminder.readthedocs.io/en/lat ... untu-16-04
digital-gnome
Test the camera with VLC if you can, or some other rtsp viewer. It looks like the url should be
rtsp://[username]:[password]@[IPADDRESS]/play2.sdp
without the brackets. Using VLC to test helps eliminate any problems there might be with your zoneminder install. It looks like it's getting a login message instead of a stream.
Nesti
Post by Nesti »
digital-gnome wrote: Wed Nov 29, 2017 10:26 pm Test the camera with VLC if you can, or some other rtsp viewer. It looks like the url should be
Ok, i going to test it.
And other things, somebody know the direction web of a free camera whit work fine for make a test?
Thanks u
Nesti wrote: Thu Nov 30, 2017 10:11 am
Thanks u
Spain Camera.jpg (49.19 KiB) Viewed 15899 times
Nesti
Post by Nesti »
does not work in VLC and no work in ZM :cry:
Log ZM:
VLC:
The VLC is in windows, I can't in ubuntu because it is ubuntu server without graphic mode, sorry :oops:
Sure does work
This is what you use in VLC even Windows version: http://212.170.22.153:8080/mjpg/video.mjpg
With your DCS-2121 camera you have two options in Zoneminder
1- JPG Stills:
Source Type: Remote
Remote Host Name: username:password@cam_ip
Remote Host Port: 80
Remote Host Path: /image/jpeg.cgi?profileid=1
or
2- MJPEG:
Source Type: Remote
Remote Host Path: /video/mjpg.cgi
Nesti
Post by Nesti »
Hello, at now VLC work fine, but I don't understand one thing.
In the VLC, if I put the ip address just doesn't work, example:
212.170.22.153
If I put the address of the website just like on the web doesn't work, example:
http://212.170.22.153:8080/view/viewer_ ... html?id=22
But if I put 212.170.22.153:8080/mjpg/video.mjpg it's works fine.
why?
I'm sorry for my ignorance :oops:
mikb
Post by mikb »
It is probably because "212.170.22.153:8080/mjpg/video.mjpg" is the raw video stream, which is what Zoneminder wants,
and
"212.170.22.1453:8080/view/viewer/...?id=22" is serving up an HTML page which surrounds the raw video stream, and Zoneminder has no idea what to do with all that HTML -- it is not a web browser.
Nesti
Post by Nesti »
The test has already done, in the VLC works perfect but in Zoneminder I still have problems.
Thanks u
Nesti
Post by Nesti »
Hi all, I think I have solved the problem, in part. I did not complete the zoneminder installation, I lacked to establish the path of the files.
But now I have another problem, I think it's something from the FSR, can someone help me?
