the screen turns blue.
cunha
Post by cunha »
good afternoon!
Need help...
I have 1 camera wifi and wanted to hook it up to zoneminder. I removed the address from the ipsy and put it in the zoneminder, but the screen turns blue.
the zoneminder is installed on the raspberry.
in the photos are the settings and model of the camera
thank you
Re: the screen turns blue.
Camera resolution in Zoneminder does not match camera output. Use VLC (Tools, Media Information, Codec) to check camera Display Resolution.
cunha
Post by cunha »
the resolution is the same. Do not know what to do?
First try ffmpeg with the same data you used in VLC Location.
For remote host name use user:password@ipaddress remote host path use /snapshot.jpg
Use 32 bit colour
Note you may have to add a password to the camera to get it to work.
cunha
Post by cunha »
sorry but it's still the same :(
