1.31.26 No Background Filters & User Authentification Problem
Alec
Post by Alec »
I've upgraded my test installation to 1.31.26 . . .
zmfilter is still not working for me:
2018-01-23 10:11:47.490290	zmfilter		13607	INF	Checking filter Purge Day-Old delete returned 0 events 	zmfilter.pl
If I "list" this filter manually, I get 24 Events.
But even worse, ZMS returns:
2018-01-23 10:22:06.680613	zms_m5		15702	ERR	Unable to authenticate user	zms.cpp	202
2018-01-23 10:22:06.641883	zms_m5		15701	ERR	Unable to authenticate user	zms.cpp	202
2018-01-23 10:22:06.600688	zms_m5		15700	ERR	Unable to authenticate user	zms.cpp	202
2018-01-23 10:22:06.555722	zms_m5		15699	ERR	Unable to authenticate user	zms.cpp	202
2018-01-23 10:22:06.515818	zms_m5		15698	ERR	Unable to authenticate user	zms.cpp	202
2018-01-23 10:22:06.475708	zms_m5		15697	ERR	Unable to authenticate user	zms.cpp	202
And, naturally, I cannot view any feeds or events . . .
I did have to do "apt install -f" to get this test installation to upgrade from 1.31.1 to 1.31.26, so something may have gone wrong unique to me, but right now I am stuck . . .
And I managed to upgrade my production install to .31.19 by accident, which does not have working background filters, so I was hoping to upgrade out of that mess once I tested out 1.31.26.
Thanks,
Alec
DFU
Re: 1.31.26 No Background Filters & User Authentification Problem
I think you need to go into options and check HASH_LOGINs... I need to review/cleanup all this AUTh stuff. It's a mess.
Alec
Post by Alec »
That was the authorization problem. Thank you. And thank you for all of the development work you have put into 1.31.
I am still having the background filter problem, however. I'm trying to understand zmfilter.pl. From the log, it appears that everything is working, just all the filters are returning "0 events". . . It's as though the queries are all broken and returning a zero set or something?
If anyone can help me understand / troubleshoot this, I'd appreciate it.
Alec
DFU
Eradicator
Post by Eradicator »
1.31.38 same auth error.
When try to watch any monitor:
2018-02-21 14:01:17.502327	zms_m1		587	ERR	Unable to authenticate user	zms.cpp
Hash logins - checked. If uncheck OPT_USE_AUTH all monitors good.
Eradicator
1.31.39 still error =(
2018-02-25 12:39:35.003631	zms_m1		629	ERR	Unable to authenticate user	zms.cpp	203
