Page 1 of 1
Unable to display Live View
Posted: Wed Jan 24, 2018 8:26 am
by zazmi
I've configure all the camera to add onto zoneminder. Unfortunately, there's nothing display (even live view) when i selected one of my monitors. I think the configuration already correct. Any idea for this error ? :?:
error zm.PNG (57.08 KiB) Viewed 2992 times
Re: Unable to display Live View
Posted: Wed Jan 24, 2018 1:37 pm
by bbunge
Did you change the PATH_ZMS?
Posted: Thu Jan 25, 2018 1:42 am
by zazmi
Hi bbunge,
Yes, i did change the Path to "zm/cgi-bin/nph-zms" , by default it was "/cgi-bin/nph-zms"
Posted: Thu Jan 25, 2018 12:40 pm
by Alec
I was having the same problem. Iconnor suggested:
go into options and check HASH_LOGINs... I need to review/cleanup all this AUTh stuff. It's a mess.
This solved the problem for me. (Even though this was not selected with earlier versions, and the system worked.)
