Bash script to manage cameras and zmtrigger
Posted: Mon Jan 29, 2018 1:26 am
Hi, I created this bash script and named it "cmd_ipcamers" (Put it into /sbin/ or other folder and give it 755 permission). It restart ZoneMinder's Cameras and (Force Manually) Start\Stop Recording.
Usage:
cmd_ipcameras {reboot|rebootid|record|recordid|stoprecord|stoprecordid|info}
reboot = Reboot all cameras (I have 7 Cameras).
rebootid <ID> = Reboot the specific ZoneMinder Camera ID.
record | stoprecord = Record all cameras (Again, I have 7 Cameras).
recordid | stoprecordid <ID> = Record the specific ZoneMinder Camera ID.
Reboot is managed by zmcontrol.pl using "--command=reset" (So, you need PTZ settings enabled and setted on your Camera [Control])
Recording is managed by zmtrigger.pl and the script send telent commands to localhost.
NOTE: Changing "cmd2" value, the script can do anything on the camera like pan\tilt etc..
"cmd_ipcameras" file:
As Arduino Sketh, I hope this can help someone.
Usage:
#!/bin/sh
host="localhost"
port="6802"
cmd1="timeout 5 zmcontrol.pl"
cmd2="--command=reset"
cmd3="|on+150|200|Manual|Record"
cmd4="|off+10|0|Manual|Stopped"
case "$1" in
'reboot')
$cmd1 --id=1 $cmd2
echo Reboot ID 1 ZoneMinder IP Camera now.
sleep 0.5
$cmd1 --id=2 $cmd2
echo Reboot ID 2 ZoneMinder IP Camera now.
sleep 0.5
$cmd1 --id=3 $cmd2
echo Reboot ID 3 ZoneMinder IP Camera now.
sleep 0.5
$cmd1 --id=4 $cmd2
echo Reboot ID 4 ZoneMinder IP Camera now.
sleep 0.5
$cmd1 --id=5 $cmd2
echo Reboot ID 5 ZoneMinder IP Camera now.
sleep 0.5
$cmd1 --id=6 $cmd2
echo Reboot ID 6 ZoneMinder IP Camera now.
sleep 0.5
$cmd1 --id=7 $cmd2
echo Reboot ID 7 ZoneMinder IP Camera now.
sleep 0.5
echo All 7 ZoneMinder IP Cameras have been successfully rebooted.
'rebootid')
$cmd1 --id=$2 $cmd2
echo Reboot ID $2 ZoneMinder IP Camera now.
'record')
( echo open $host $port
sleep 0.5
echo 1$cmd3
sleep 0.5
echo 2$cmd3
sleep 0.5
echo 3$cmd3
sleep 0.5
echo 4$cmd3
sleep 0.5
echo 5$cmd3
sleep 0.5
echo 6$cmd3
sleep 0.5
echo 7$cmd3
sleep 0.5 ) | telnet
sleep 0.5
echo Record command sent to all 7 ZoneMinder IP Cameras.
'recordid')
sleep 0.5
echo $2$cmd3
sleep 0.5
echo Record command sent to ID $2 ZoneMinder IP Camera.
'stoprecord')
sleep 0.5
echo 1$cmd4
sleep 0.5
echo 2$cmd4
sleep 0.5
echo 3$cmd4
sleep 0.5
echo 4$cmd4
sleep 0.5
echo 5$cmd4
sleep 0.5
echo 6$cmd4
sleep 0.5
echo 7$cmd4
sleep 0.5
echo Stop record command sent to all 7 ZoneMinder IP Cameras.
'stoprecordid')
sleep 0.5
echo $2$cmd4
sleep 0.5
'info')
echo "Use reboot/record/stoprecord or rebootid/recordid/stoprecordid <ID> parameters to reboot or (stop)record IP Cameras manually"
echo "Usage: $0 {reboot|rebootid|record|recordid|stoprecord|stoprecordid|info}"
exit 1
esac
exit 0
