Multiserver don't show image
juanmoura
Post by juanmoura »
I am using the zoneminder server separate from the database, using as multiserver.
It was all set up and I can already access via web. In the server tab it has already been inserted and already shows me the server data, load, memory, swap.
But it does not display the images anymore, when I return zm.conf to the default the images reappear.
juanmoura
Re: Multiserver don't show image
Post by juanmoura »
Updating my problem, I managed to make the multi-server work, I am able to see live, I am able to watch recordings, but with several remarks regarding the tutorial that is on the site:
zoneminder.readthedocs.io/en/stable/installationguide/multiserver.html
You have to inform that you have to enter the mysql / mariadb settings and the BIND change to 0.0.0.0
And when giving the permission to change the localhost by the ip of the server that will communicate with the database, a permission for each IP that is to connect.
First change in /etc/zm/zm.conf and then populate via web browser with the created hostnames.
