Ubuntu Server 17.10
pgleed
Ubuntu Server 17.10
Post by pgleed »
I hope someone can help me, I have tried everything I possibly could google to fix the issue, since Ubuntu updated to Ver17.10 I can no longer log into Zoneminder WEB UI interface. I am running Ubuntu Server 17.10 and Zoneminer Ver 1.30.4. Every time I go to http://localhost/zm I get this:
<?php
// ZoneMinder main web interface file, $Date$, $Revision$
// Copyright (C) 2001-2008 Philip Coombes
// This program is free software; you can redistribute it and/or
// modify it under the terms of the GNU General Public License
// as published by the Free Software Foundation; either version 2
// of the License, or (at your option) any later version.
// This program is distributed in the hope that it will be useful,
// but WITHOUT ANY WARRANTY; without even the implied warranty of
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
// GNU General Public License for more details.
// You should have received a copy of the GNU General Public License
// along with this program; if not, write to the Free Software
// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA.
error_reporting( E_ALL );
$debug = false;
if ( $debug )
// Use these for debugging, though not both at once!
phpinfo( INFO_VARIABLES );
//error_reporting( E_ALL );
// Use new style autoglobals where possible
if ( version_compare( phpversion(), "4.1.0", "<") )
$_SESSION = &$HTTP_SESSION_VARS;
$_SERVER = &$HTTP_SERVER_VARS;
// Useful debugging lines for mobile devices
if ( false )
ob_start();
$fp = fopen( "/tmp/env.html", "w" );
fwrite( $fp, ob_get_contents() );
fclose( $fp );
ob_end_clean();
require_once( 'includes/config.php' );
require_once( 'includes/logger.php' );
require_once( 'includes/Server.php' );
require_once( 'includes/Storage.php' );
require_once( 'includes/Monitor.php' );
if ( isset($_SERVER["HTTPS"]) && $_SERVER["HTTPS"] == 'on' )
$protocol = 'https';
else
$protocol = 'http';
define( "ZM_BASE_PROTOCOL", $protocol );
// Absolute URL's are unnecessary and break compatibility with reverse proxies
// define( "ZM_BASE_URL", $protocol.'://'.$_SERVER['HTTP_HOST'] );
// Use relative URL's instead
define( "ZM_BASE_URL", "" );
// Check time zone is set
if (!ini_get('date.timezone') || !date_default_timezone_set(ini_get('date.timezone'))) {
date_default_timezone_set('UTC');
Fatal( "ZoneMinder is not installed properly: php's date.timezone is not set to a valid timezone" );
if ( isset($_GET['skin']) )
$skin = $_GET['skin'];
elseif ( isset($_COOKIE['zmSkin']) )
$skin = $_COOKIE['zmSkin'];
elseif ( defined('ZM_SKIN_DEFAULT') )
$skin = ZM_SKIN_DEFAULT;
else
$skin = "classic";
$skins = array_map( 'basename', glob('skins/*',GLOB_ONLYDIR) );
if ( ! in_array( $skin, $skins ) ) {
Error( "Invalid skin '$skin' setting to " . $skins[0] );
$skin = $skins[0];
if ( isset($_GET['css']) )
$css = $_GET['css'];
elseif ( isset($_COOKIE['zmCSS']) )
$css = $_COOKIE['zmCSS'];
elseif (defined('ZM_CSS_DEFAULT'))
$css = ZM_CSS_DEFAULT;
else
$css = "classic";
$css_skins = array_map( 'basename', glob('skins/'.$skin.'/css/*',GLOB_ONLYDIR) );
if ( ! in_array( $css, $css_skins ) ) {
Error( "Invalid skin css '$css' setting to " . $css_skins[0] );
$css = $css_skins[0];
define( "ZM_BASE_PATH", dirname( $_SERVER['REQUEST_URI'] ) );
define( "ZM_SKIN_NAME", $skin );
define( "ZM_SKIN_PATH", "skins/$skin" );
$skinBase = array(); // To allow for inheritance of skins
if ( !file_exists( ZM_SKIN_PATH ) )
Fatal( "Invalid skin '$skin'" );
$skinBase[] = $skin;
$currentCookieParams = session_get_cookie_params();
Debug('Setting cookie parameters to lifetime('.$currentCookieParams['lifetime'].') path('.$currentCookieParams['path'].') domain ('.$currentCookieParams['domain'].') secure('.$currentCookieParams['secure'].') httpOnly(1)');
session_set_cookie_params(
$currentCookieParams["lifetime"],
$currentCookieParams["path"],
$currentCookieParams["domain"],
$currentCookieParams["secure"],
true
ini_set( "session.name", "ZMSESSID" );
session_start();
if ( !isset($_SESSION['skin']) || isset($_REQUEST['skin']) || !isset($_COOKIE['zmSkin']) || $_COOKIE['zmSkin'] != $skin )
$_SESSION['skin'] = $skin;
setcookie( "zmSkin", $skin, time()+3600*24*30*12*10 );
if ( !isset($_SESSION['css']) || isset($_REQUEST['css']) || !isset($_COOKIE['zmCSS']) || $_COOKIE['zmCSS'] != $css ) {
$_SESSION['css'] = $css;
setcookie( "zmCSS", $css, time()+3600*24*30*12*10 );
if ( ZM_OPT_USE_AUTH )
if ( isset( $_SESSION['user'] ) )
$user = $_SESSION['user'];
else
unset( $user );
else
$user = $defaultUser;
require_once( 'includes/lang.php' );
require_once( 'includes/functions.php' );
require_once( 'includes/csrf/csrf-magic.php' );
# Add Cross domain access headers
CORSHeaders();
// Check for valid content dirs
if ( !is_writable(ZM_DIR_EVENTS) || !is_writable(ZM_DIR_IMAGES) )
Error( "Cannot write to content dirs('".ZM_DIR_EVENTS."','".ZM_DIR_IMAGES."'). Check that these exist and are owned by the web account user");
if ( isset($_REQUEST['view']) )
$view = detaintPath($_REQUEST['view']);
if ( isset($_REQUEST['request']) )
$request = detaintPath($_REQUEST['request']);
if ( isset($_REQUEST['action']) )
$action = detaintPath($_REQUEST['action']);
foreach ( getSkinIncludes( 'skin.php' ) as $includeFile )
require_once $includeFile;
# The only variable we really need to set is action. The others are informal.
isset($view) || $view = NULL;
isset($request) || $request = NULL;
isset($action) || $action = NULL;
if ( ZM_ENABLE_CSRF_MAGIC && $action != 'login' ) {
Debug("Calling csrf_check with the following values: \$request = \"$request\", \$view = \"$view\", \$action = \"$action\"");
csrf_check();
require_once( 'includes/actions.php' );
# If I put this here, it protects all views and popups, but it has to go after actions.php because actions.php does the actual logging in.
if ( ZM_OPT_USE_AUTH && ! isset($user) && $view != 'login' ) {
$view = 'login';
# Only one request can open the session file at a time, so let's close the session here to improve concurrency.
# Any file/page that uses the session must re-open it.
session_write_close();
if ( isset( $_REQUEST['request'] ) )
foreach ( getSkinIncludes( 'ajax/'.$request.'.php', true, true ) as $includeFile )
if ( !file_exists( $includeFile ) )
Fatal( "Request '$request' does not exist" );
return;
else
if ( $includeFiles = getSkinIncludes( 'views/'.$view.'.php', true, true ) )
foreach ( $includeFiles as $includeFile )
Fatal( "View '$view' does not exist" );
// If the view overrides $view to 'error', and the user is not logged in, then the
// issue is probably resolvable by logging in, so provide the opportunity to do so.
// The login view should handle redirecting to the correct location afterward.
if ( $view == 'error' && !isset($user) )
$view = 'login';
foreach ( getSkinIncludes( 'views/login.php', true, true ) as $includeFile )
// If the view is missing or the view still returned error with the user logged in,
// then it is not recoverable.
if ( !$includeFiles || $view == 'error' )
foreach ( getSkinIncludes( 'views/error.php', true, true ) as $includeFile )
Re: Ubuntu Server 17.10
something is wrong with the Apache web server configuration I think!
Zoneminder in Ubuntu 17.10 is broken. When you upgraded your good install was overwritten. Your choices are to uninstall Zoneminder and reinstall following the WIKI instructions or start over with a fresh Ubuntu, 16.04 recommended.
If your webserver is literally posting the php script to your browser, that means you either don't have php installed or you are missing a php module in your webserver config.
knnniggett wrote: Tue Feb 13, 2018 12:37 am If your webserver is literally posting the php script to your browser, that means you either don't have php installed or you are missing a php module in your webserver config.
There was also a change in PHP from 17.04 to 17.10.
17.04 uses PHP 7.0 while 17.10 uses PHP 7.1
This may, in part, be your problem. You can spend time figuring out how to fix it and still not get Zoneminder to work. Sorry to say starting over may save time and stress.
