1.31.39 SQL error on clean install
Eradicator
Post by Eradicator »
Hi!
Tried to make clean install to resolve auth problem (described in auth problem topic) but encountered SQL error at install.
Tried to make
same error:
ERROR 1064 (42000) at line 420: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 48
P.S.I tested all builds of 1.31 and want to share testing experience but dont know how to do it correctly. Can anyone tell how make bugreport right? Thanks!
P.P.S. Sorry if it is trivial error. My SQL knowledge is too basic for this. :(
Re: 1.31.39 SQL error on clean install
MySQL or Mariadb?
Did you make the changes to the my.cnf?
Eradicator
bbunge wrote: Mon Feb 26, 2018 12:54 pm MySQL or Mariadb?
MySQL from lamp-server.
My.cnf default (from /etc/mysql/mysql.conf.d/mysqld.cnf) with addition: sql_mode = NO_ENGINE_SUBSTITUTION
Eradicator
Tried on second test server. Problem exist! Did anyone clean install 1.31.39? May be some changes in installation? Is that manual correct?
http://zoneminder.readthedocs.io/en/lat ... untu-16-04
There will be a new release tonight that should resolve this.
Eradicator
iconnor wrote: Fri Mar 02, 2018 3:50 am There will be a new release tonight that should resolve this.
Thank you very much!
