Page 1 of 1
Best Camera to use?
Posted: Thu Mar 01, 2018 5:21 pm
by jimkoh
I have ZoneMinder 1.29 set up on my Debian server. I have never been able to get a picture with the camera's I currently have, but they stream to VLC without a problem. I'm looking at replacing my existing Jennov camera's with something that works. I know there are a lot of camera's that people have made work, but I want to know which brand/model to get that will work without all kinds of workarounds. I'm looking for a 3-4 mp camera and don't want to spend several hundred dollars on each one as I'm going to be installing 8 total. POE camera's are preferred.
Jim
Re: Best Camera to use?
Posted: Thu Mar 01, 2018 6:17 pm
by bbunge
If your cameras stream to VLC they will work in Zoneminder. Use the same stream in ffmpeg and the same resolution VLC reports.
Posted: Thu Mar 01, 2018 7:03 pm
by jimkoh
I know it should work that way...but here's the link to my other post describing the problem. So far nothing has worked, which is why I was asking about new camera's.
viewtopic.php?f=34&t=26748
Posted: Fri Mar 02, 2018 12:01 am
by bbunge
Looks like it is a Dahua knock off. See:
https://wiki.zoneminder.com/Dahua
rtsp://admin:admin@192.168.1.100:554/cam/realmonitor?channel=1&subtype=0 - should be the Source Path string as well as the string to use in VLC. Get it working in VLC and check resolution reported.
Camera resolution in Zoneminder does not match camera output. Use VLC (Tools, Media Information, Codec) to check camera Display Resolution.
Posted: Fri Mar 02, 2018 6:24 pm
by jimkoh
I tried the settings you mentioned as well as the info from the wiki. The best I get is a black screen in IE. I've attached a screen shot of the codec information from VLC
Posted: Fri Mar 02, 2018 7:48 pm
by bbunge
Use a browser other than IE. IE needs Java installed and the cambozola in zm.
Posted: Sat Mar 03, 2018 4:55 pm
by jimkoh
I've tried Firefox, Chromium and Konqueror. None of them show video. The reason I tried IE is because the native camera software will only work with that due to Flash/SWF, and I thought if I could at least get video in IE then I could troubleshoot the others.
