rtsp audio stream recording and live streaming
Zm-king
Post by Zm-king »
Hi All,
I am using snx_rtsp_server to streaming the video and audio from IP cam. It works perfectly with VLC.
How can ZM to record the audio and get audio on live streaming ?
In Monitor setting -> Storage, there is "Whether to store the audio stream when saving an event" , How this works ?
I enabled it but looks not any different
Dulanic
Re: rtsp audio stream recording and live streaming
Post by Dulanic »
Did you ever determine anything? My ZM works fine without audio turned on, but if I enable audio and passthrough, it can't playback anything. It just says not supported. VLC works for me too.
You have to use the ffmpeg source type.
