Viewing event in zmninja causes this error..
maxiedaniels
Post by maxiedaniels »
I'm seeing this when I try to view an event in zmninja:
"Socket /var/run/zm/zms-[somenumber]s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit."
I've double checked and my 01-system-paths.conf inside /etc/zm/conf.d has PATH_ZMS set the way it should be (/zm/cgi-bin/nph-zms).
This is using the storageareas PPA version of ZM. 1.31.39
Any thoughts?
Re: Viewing event in zmninja causes this error..
Common error caused by your browser. Do not worry about it.
maxiedaniels
To clarify - when this happens, zmninja goes to a screen with a red error saying “could not retrieve frame details”
is the camera monitor [somenumber] disconnecting and reconnecting? Is an event generated with the cause Signal?
maxiedaniels
No - I don't see anything about disconnecting or reconnecting. And I don't see anything about signal.
Literally all that happens is I press footage to view an event on zmninja, I get the error "could not retrieve frame details" on zmninja and nothing appears (just a grey screen with the red error and a back arrow), and on zone minder's log page I see the socket error I wrote above.
share which operating system you are using and does ZM stream the cameras when accessed through the ZM web console?
maxiedaniels
Ubuntu 17.19. Yes ZM in the browser streams fine and shows event footage fine.
canbikehere
Post by canbikehere »
I just upgraded my system to 1.31.39 yesterday, I'm experiencing the same issue with ZMNinja. Everything works fine in the browser, zmninja shows the "could not retrieve frame details" error.
I also see this in my Zoneminder logs:
2018-03-21 10:28:46.438171 web_php 13822 FAT Can't create frame images from video for this event (5550-video.mp4 /usr/share/zoneminder/www/views/image.php 121
what version of php are you using? This sounds like an ZM API problem. Test the to see if it is working and use the url ->
http://your-zm-server/zm/api/host/getVersion.json in a browser. it should show a version number...if not the API is broken and zmNinja needs the ZM API to work.....
maxiedaniels
API is working, `{"version":"1.31.39","apiversion":"1.0"}`
PHP is PHP 7.1.15-0ubuntu0.17.10.1.
oh that is different. can you turn on a deeper level of debug?
canbikehere
Same here -
PHP info:
libapache2-mod-php7.0:amd64/xenial-security 7.0.28-0ubuntu0.16.04.1
php7.0-common:amd64/xenial-security 7.0.28-0ubuntu0.16.04.1
maxiedaniels
rockedge wrote: Wed Mar 21, 2018 11:58 pm oh that is different. can you turn on a deeper level of debug?
What level debug would I need to enable? I tried level 3, nothing more is showing up.
really push it higher to 7-9 at least to see something in the logs. both cases seem similar, all the functions with ZM through the web console work? zmNinja is the only place you are generating these errors?
maxiedaniels
Ah - got it. It was in a different log file. This is definitely the error.
2018-03-22 10:05:43 Error: [ParseError] syntax error, unexpected ';', expecting ')'
Request URL: /zm/api/events/5391.json
Stack Trace:
#0 [internal function]: App::load('Group')
#1 [internal function]: spl_autoload_call('Group')
#2 /usr/share/zoneminder/www/api/lib/Cake/Utility/ClassRegistry.php(146): class_exists('Group')
#3 /usr/share/zoneminder/www/api/lib/Cake/Model/Model.php(1077): ClassRegistry::init('Group')
#4 /usr/share/zoneminder/www/api/lib/Cake/Model/Model.php(886): Model->_constructLinkedModel('Group', 'Group', NULL)
#5 /usr/share/zoneminder/www/api/lib/Cake/Model/Model.php(919): Model->__isset('Group')
#6 /usr/share/zoneminder/www/api/lib/Cake/Model/Datasource/DboSource.php(1132): Model->__get('Group')
#7 /usr/share/zoneminder/www/api/lib/Cake/Model/Model.php(3031): DboSource->read(Object(Event), Array)
#8 /usr/share/zoneminder/www/api/lib/Cake/Model/Model.php(3003): Model->_readDataSource('first', Array)
#9 /usr/share/zoneminder/www/api/app/Controller/EventsController.php(120): Model->find('first', Array)
#10 [internal function]: EventsController->view('5391')
#11 /usr/share/zoneminder/www/api/lib/Cake/Controller/Controller.php(491): ReflectionMethod->invokeArgs(Object(EventsController), Array)
#12 /usr/share/zoneminder/www/api/app/Plugin/Crud/Lib/CrudControllerTrait.php(31): Controller->invokeAction(Object(CakeRequest))
#13 /usr/share/zoneminder/www/api/lib/Cake/Routing/Dispatcher.php(193): AppController->invokeAction(Object(CakeRequest))
#14 /usr/share/zoneminder/www/api/lib/Cake/Routing/Dispatcher.php(167): Dispatcher->_invoke(Object(EventsController), Object(CakeRequest))
#15 /usr/share/zoneminder/www/api/app/webroot/index.php(107): Dispatcher->dispatch(Object(CakeRequest), Object(CakeResponse))
#16 {main}
