Rasp 3 with StorageAreas
juanmoura
Post by juanmoura »
Looking in the stable and master repo i found the compatibility with arm devices, but in the storage areas repo don't.
Have any way to install on the Raspberry? I'm using Ubuntu Mate with Master repo. I will created a multiservers with very rasps, for that i will need the alocate the images in different directories.
juanmoura
Re: Rasp 3 with StorageAreas
Post by juanmoura »
i install with the stable repo and change de PATH for the CGI, but when i update for MASTER repo and ADD any camera i found this.
ERR Socket /var/run/zm/zms-888784s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/lat ... window-etc for more information.
And the imagens don't appear to me.
change or add the repo from "master" to "storageareas"
deb http://ppa.launchpad.net/iconnor/zoneminder-storageareas/ubuntu
juanmoura
Post by juanmoura »
But the "storageareas" repo in the ppa not have the version for armhf. Just amd64 and i386.
