Filters: total disk space used?
maxiedaniels
Post by maxiedaniels »
It seems 'disk space' in the filters equates to the space used for each event. I'd like to delete events if the *total* space by all events goes over a certain amount... is this possible?
maxiedaniels
Re: Filters: total disk space used?
Anybody?
I have no idea how you came to that conclusion.
The default purge when full filter, that ships with ZoneMinder, does exactly what you are asking.
maxiedaniels
I tested the disk space filter, which seems to relate to the size of an individual event..
The purge when full filter uses disk percent, not disk space. Disk percent I can't use because I'm not using a dedicated drive so disk percent isn't relevant. (I'm using StorageAreas)
