I've installed zmNinja Android App which is used to enable/disable monitors of a zoneminder v1.30.4 instance. Unfortunately this is only possible if the user has the System-Edit privilege (Monitor-Edit privilege is not sufficient !) Probably this is a security bug within the ZM-API, since it works from the Web-GUI ?
Are there any workarounds / bugfixes so far?
Kind regards
zmNinja - ZM-User permission
Re: zmNinja - ZM-User permission
yes there is a way. modify the code a little to add the logic. here is an example:
viewtopic.php?p=100570#p100570
you want a Monitor-Edit privilege so a limited user has the ability to turn a monitor on/off?
make sure you modify the correct "skin" code.
I tested version 1.31.1 and with a user called "justlook" that has privileges to Stream=view, Monitor=edit
in zmNinja logged in as "justlook" and I was able to turn on/off and enable/disable each monitor individually and globally.
