Hi guys,
I just setup a zoneminder system with Fedora 27 using the official docs and everything run ok. The box is xSeries M5 with 02 CPU (20 cores) and 256GB RAM, 256GB RAID1 for OS and 4.5TB RAID0 for camera data.
The question I have is how to config optimum mysql and other things in system for 200+ cameras + using modect method.
Thanks guys,
Simon
Need advise - Fedora 27 - system optimum setting
- knight-of-ni
Re: Need advise - Fedora 27 - system optimum setting
sudo dnf install mysqltuner
Here is my writeup on the topic:
http://zoneminder.blogspot.com/p/blog-page_19.html
Thank you very much,
I will look into that,
Just to update, I follow the recommendation and restart mysql, then run the mysqltuner again, no more recommendation so far
