Page 1 of 1
Need advise - Fedora 27 - system optimum setting
Posted: Mon Apr 16, 2018 10:14 am
by quynh.ht
Hi guys,
I just setup a zoneminder system with Fedora 27 using the official docs and everything run ok. The box is xSeries M5 with 02 CPU (20 cores) and 256GB RAM, 256GB RAID1 for OS and 4.5TB RAID0 for camera data.
The question I have is how to config optimum mysql and other things in system for 200+ cameras + using modect method.
Thanks guys,
Simon
Re: Need advise - Fedora 27 - system optimum setting
Posted: Mon Apr 16, 2018 5:38 pm
by knight-of-ni
sudo dnf install mysqltuner
Then just do what it says.
Here is my writeup on the topic:
http://zoneminder.blogspot.com/p/blog-page_19.html
Posted: Tue Apr 17, 2018 1:28 am
by quynh.ht
Thank you very much,
I will look into that,
Just to update, I follow the recommendation and restart mysql, then run the mysqltuner again, no more recommendation so far :)
