OpenMediaVault, Raspberry PI2, Zoneminder, Webinterface
ejvl
Post by ejvl »
Hi all,
I’ve a Raspberry Pi2 installed with OpenMediaVault, (Debian 8 Jessie), changed the webinterface port to 81. That works fine.
I’ve installed Zoneminder with those instructions,
https://wiki.zoneminder.com/Debian_8_64 ... e_Easy_Way
The installation is fine, but the webinterface does not works.
In Internet Explorer, I’ve seen a blank page.
In Chrome, the PHP file is appear:
<?php
// ZoneMinder main web interface file, $Date$, $Revision$
// Copyright (C) 2001-2008 Philip Coombes
// This program is free software; you can redistribute it and/or
// modify it under the terms of the GNU General Public License
// as published by the Free Software Foundation; either version 2
// of the License, or (at your option) any later version.
// This program is distributed in the hope that it will be useful,
// but WITHOUT ANY WARRANTY; without even the implied warranty of
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
// GNU General Public License for more details.
// You should have received a copy of the GNU General Public License
// along with this program; if not, write to the Free Software
// Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
Etc.
But nothing opened yet. No webbrowser.
The ZoneMinder service is working well for so far I know:
root@raspberrypi:~# systemctl status zoneminder.service
● zoneminder.service - ZoneMinder CCTV recording and surveillance system
Loaded: loaded (/lib/systemd/system/zoneminder.service; enabled)
Active: active (running) since Tue 2018-04-17 09:34:46 CEST; 5min ago
Process: 2029 ExecStart=/usr/bin/zmpkg.pl start (code=exited, status=0/SUCCESS)
Main PID: 2200 (zmdc.pl)
CGroup: /system.slice/zoneminder.service
├─2200 /usr/bin/perl -wT /usr/bin/zmdc.pl startup
├─2251 /usr/bin/perl -wT /usr/bin/zmfilter.pl
├─2283 /usr/bin/perl -wT /usr/bin/zmaudit.pl -c
└─2306 /usr/bin/perl -wT /usr/bin/zmwatch.pl
Apr 17 09:34:45 raspberrypi sudo[2255]: pam_unix(sudo:session): session closed for user www-data
Apr 17 09:34:45 raspberrypi sudo[2287]: root : TTY=unknown ; PWD=/usr/share/zoneminder/www ; USER=www-data ; COMMAND=/usr/bin/zmdc.pl star...watch.pl
Apr 17 09:34:45 raspberrypi sudo[2287]: pam_unix(sudo:session): session opened for user www-data by (uid=0)
Apr 17 09:34:46 raspberrypi zmdc[2200]: INF ['zmwatch.pl' starting at 18/04/17 09:34:46, pid = 2306]
Apr 17 09:34:46 raspberrypi zmdc[2306]: INF ['zmwatch.pl' started at 18/04/17 09:34:46]
Apr 17 09:34:46 raspberrypi sudo[2287]: pam_unix(sudo:session): session closed for user www-data
Apr 17 09:34:46 raspberrypi zmfilter[2251]: INF [Scanning for events]
Apr 17 09:34:46 raspberrypi systemd[1]: Started ZoneMinder CCTV recording and surveillance system.
Apr 17 09:34:47 raspberrypi zmwatch[2306]: INF [Watchdog starting]
Apr 17 09:34:47 raspberrypi zmwatch[2306]: INF [Watchdog pausing for 30 seconds]
I don’t know how to fix it, any idea?
Thanks.
Update, I've changed the "short_open_tag = Off" to "shart_open_tag=On" and restart the apache services, but no result.
