Page 1 of 1
Recording Many Events Cause Signal
Posted: Tue Apr 17, 2018 11:57 am
by juanmoura
In my environment I have several cameras that are not INFRA, and I have seen a lot of events with SIGNAL cause. This is very difficult to remove with the filter, even because the removal is by event, is there any way of not recording these events with cause SIGNAL?
Re: Recording Many Events Cause Signal
Posted: Sat Apr 21, 2018 2:39 pm
by juanmoura
When i create a filter for delete all events with cause Signal does not remove.
I need to delete manually causing a lot work.
I think if the camera don't have a infra red fuction, the image will be black in the night, so i don't need to record events with cause signal. This only enlarge my database causing a lot trouble.
In one night i've more than 5000 events with de cause Signal and smal than 5s and 4kb.
When the filter purgewhenfull enter in action these events will deprecite the capability for exclusion and liberate the space in disk.
Posted: Sat Apr 21, 2018 11:24 pm
by rockedge
I use a filter for Cause = Signal like this ->
- ZM-filter-ex.png (57.78 KiB) Viewed 4108 times
Posted: Sun Apr 22, 2018 2:44 am
by juanmoura
In this way theoretically I would remove files and data that the system has already inserted unnecessarily. What I'm looking for is a way for him not to create those events that are useless. Even so, the filter only works if I list the items and select and delete them all manually. Creating a filter to automatically remove and rotate in the background does not work, it does not remove, it only consumes memory and processing without need, I follow everything with Zabbix.
Posted: Sun Apr 22, 2018 5:04 pm
by rockedge
are you saying the Filters when Delete all matches is selected does not work? Please open a terminal and enter ->
are there errors?
Posted: Mon Apr 23, 2018 7:44 pm
by juanmoura
Running zmfilter.pl in the terminal the filter works, but in webpage don't.
Posted: Sun May 06, 2018 7:31 pm
by juanmoura
rockedge wrote: ↑Sat Apr 21, 2018 11:24 pm
Adding here some news, so running version 1.31.42, we have many recordings with Cause = Signal, however the consumption is minimal, what happens is that the disk filled and however I set it to delete 500 events in the filters when it it will filter it obviously mix cause = motion causes with cause = signal.
If I insert another filter as you gave the idea, being cause = signal and change the purgewhenfull to only cause = motion, it in fact only excludes the motions events in a filter and signal in the other filter, but it will only rotate again daemon when all the filters are gone. That way I remain the same, the exclusion time is less than the time consuming the HD. I have to see another way to remove cause = signal events, in fact I wanted to see a way to DISABLE the creation of those events, they serve no purpose, just increase the consumption of unnecessary resources.
