Zoneminder always starts in a stopped state after reboot/shutdown
Posted: Sun Apr 22, 2018 6:56 pm
I always have to open the web UI and change the state to get it to start. I've been using Zoneminder 1.30.0 for over a year now and I have never been able to find a fix for this issue. And YES I have tried the Sleep 15 flag in the config before you say read the FAQs. I've tried increasing it to sleep 30 and even 200. Does anyone have any other ideas? Here is a copy of my /etc/init.d/zoneminder
. /lib/lsb/init-functions
prog=ZoneMinder
ZM_PATH_BIN="/usr/bin"
RUNDIR="/var/run/zm"
TMPDIR="/tmp/zm"
command="$ZM_PATH_BIN/zmpkg.pl"
start() {
echo -n "Starting $prog: "
export TZ=:/etc/localtime
mkdir -p "$RUNDIR" && chown www-data:www-data "$RUNDIR"
mkdir -p "$TMPDIR" && chown www-data:www-data "$TMPDIR"
sleep 15
$command start
RETVAL=$?
[ $RETVAL = 0 ] && echo success
[ $RETVAL != 0 ] && echo failure
echo
[ $RETVAL = 0 ] && touch /var/lock/zm
return $RETVAL
stop() {
echo -n "Stopping $prog: "
# Why is this status check being done?
# as $command stop returns 1 if zoneminder
# is stopped, which will result in
# this returning 1, which will stuff
# dpkg when it tries to stop zoneminder before
# uninstalling . . .
result=`$command status`
if [ ! "$result" = "running" ]; then
echo "Zoneminder already stopped"
echo
RETVAL=0
else
$command stop
RETVAL=$?
echo
[ $RETVAL = 0 ] && rm -f /var/lock/zm
fi
status() {
if [ "$result" = "running" ]; then
echo "ZoneMinder is running"
RETVAL=0
else
echo "ZoneMinder is stopped"
RETVAL=1
fi
case "$1" in
'start')
start
'stop')
stop
'restart' | 'force-reload')
stop
start
'status')
status
echo "Usage: $0 { start | stop | restart | status }"
RETVAL=1
esac
exit $RETVAL
prog=ZoneMinder
TMPDIR="/tmp/zm"
start() {
sleep 15
$command start
RETVAL=$?
echo
return $RETVAL
stop() {
echo
RETVAL=0
else
$command stop
RETVAL=$?
echo
fi
status() {
RETVAL=0
else
RETVAL=1
fi
case "$1" in
'start')
start
'stop')
stop
stop
start
'status')
status
RETVAL=1
esac
exit $RETVAL
