Fresh install, New Monitor, No video.
Posted: Mon Apr 23, 2018 11:46 am
I set up ZoneMinder 1.30.4 according to the WIki on a fresh install of Ubuntu Server 16.04.4. (Only took me like 18 tries.) And now I'm setting up my first monitor.
My camera is a Hikvision DS-2CD2042WD-I.
I have set it up with the following path for the stream.
rtsp://UserName:ClearTextPassword@192.168.1.64//Streaming/Channels/1
Remote Method: TCP
Options: (Nothing)
ColorSpace: 32 BIt
Width and Height: 2688 and 1520
Server: None
Source Type: FFMJPEG
Function: Record (I've played around with setting this to MoDetect)
20 frames per sec is in all three fields, Analysis, Maximum, and Alarm
If I put the similar string into VLC on my laptop, I get video (Delayed by about 5 Sec)
rtsp://UserName:ClearTextPassword@192.168.1.64//Streaming/Channels/2
When I click on "Monitor-1" in the ZoneMinder front end I do not see video. (Even though it has captured events, probably from when I had it set up as MoDetect.)
It should be noted that I am also on a fresh install of Windows 10 on my laptop.
I am unsure if I need a plugin on the laptop or need to reconfigure ZoneMinder.
Remote Method: TCP
Options: (Nothing)
ColorSpace: 32 BIt
Server: None
