Page 1 of 1
Problem no images Ubuntu 18.04
Posted: Thu May 03, 2018 6:31 am
by zrock
after putting ubuntu 18.05 Lamp server mysql phpmyadmin , zoneminder 1.30.4
No image zoneminder
lsmod | grep bttv
bttv 147456 1
tea575x 16384 1 bttv
tveeprom 24576 1 bttv
videobuf_dma_sg 20480 1 bttv
videobuf_core 28672 2 bttv,videobuf_dma_sg
rc_core 36864 1 bttv
v4l2_common 16384 1 bttv
videodev 184320 4 tea575x,v4l2_common,bttv
i2c_algo_bit 16384 2 bttv,i915
dmesg | grep 878
[ 0.072350] pci 0000:07:04.1: [109e:0878] type 00 class 0x048000
[ 14.700591] bttv: 0: Bt878 (rev 17) at 0000:07:04.0, irq: 20, latency: 32, mmio: 0xf0700000
[ 14.700822] bttv: 0: using: GrandTec Multi Capture Card (Bt878) [card=77,insmod option]
ls /dev/video0
/dev/video0
is work
/etc/modprobe.d$ pico bttv.conf
options i2c-algo-bit bit_test=1
options bttv gbuffers=32 card=102,102,102,102,102,102,102,102 radio=0,0,0,0,0,0,0,0 tuner=4,4,4,4,4,4,4,4 combfilter=1 chroma_agc=1 coring=1 full_luma_range=1
/etc/modprobe.d$ pico modprobe.conf
options bttv card=77 tuner=4 radio=0 triton1=0 vsfx=0 autoload=0
but MOnitor no image zone minder
log zoneminder
2018-05-03 09:27:46.386327 zmc_dvideo0 11058 INF Monitor-2: 10000 - Capturing at 25.00 fps zm_monitor.cpp 3125
2018-05-03 09:27:06.385717 zmc_dvideo0 11058 INF Monitor-2: 9000 - Capturing at 25.00 fps zm_monitor.cpp 3125
2018-05-03 09:26:26.385122 zmc_dvideo0 11058 INF Monitor-2: 8000 - Capturing at 25.00 fps zm_monitor.cpp 3125
2018-05-03 09:25:46.384519 zmc_dvideo0 11058 INF Monitor-2: 7000 - Capturing at 25.00 fps zm_monitor.cpp 3125
2018-05-03 09:25:06.383919 zmc_dvideo0 11058 INF Monitor-2: 6000 - Capturing at 25.00 fps zm_monitor.cpp 3125
2018-05-03 09:24:26.383332 zmc_dvideo0 11058 INF Monitor-2: 5000 - Capturing at 25.00 fps zm_monitor.cpp 3125
2018-05-03 09:23:46.382723 zmc_dvideo0 11058 INF Monitor-2: 4000 - Capturing at 25.00 fps zm_monitor.cpp 3125
2018-05-03 09:23:06.382131 zmc_dvideo0 11058 INF Monitor-2: 3000 - Capturing at 25.00 fps zm_monitor.cpp 3125
2018-05-03 09:22:26.381556 zmc_dvideo0 11058 INF Monitor-2: 2000 - Capturing at 25.00 fps zm_monitor.cpp 3125
Where is the problem ?
Re: Problem no images Ubuntu 18.04
Posted: Thu May 03, 2018 8:24 am
by zrock
/zm/cgi-bin/nph-zms
OK
Posted: Thu May 03, 2018 11:55 am
by bbunge
Did you use the wiki install instructions?
