1.31.44 libvlc not working ffmpeg pixalated
elchavodel8
Post by elchavodel8 »
having problem with one camera that before was using libvlc, now if i use libvlc its stop each 4 seconds for some reason, and if i use ffmpeg the pixture get broken like pixelated, i had same problem with ffmpeg in that camera before using the 1.30.4 thats why i was using libvlc , but now i cant use libvlc with 1.31.44. any help?
Here some pictures of how it looks using ffmpeg , also i have other camera that uses ffmpeg and work nice is just this one that had this problem. Also i don't now if may have something to do but the camera that works with ffmpeg well uses TCP and the one that won't uses UDP metod because won't work if i put TCP
elchavodel8
Re: 1.31.44 libvlc not working ffmpeg pixalated
Ok i found a solution here https://github.com/ZoneMinder/zoneminder/issues/811 to make it work with ffmpeg , increasing the buffer size at source tab of the camera i put buffer_size=128000 and for now seems work good
