S905/S912 based platforms
Posted: Mon May 07, 2018 10:25 pm
Has anyone burned one of the TV Box platforms with Armbian and tried Zoneminder on them? The S905 based MXQ Pro is capable of h.265 which could be very useful for image & video processing. These boxes can be had quite cheap, I currently run one using openelec.
MXQ Pro specifications:
John
- SoC – Amlogic S905 quad core ARM Cortex-A53 @ up to 2.0GHz with penta-core Mali-450MP GPU
- System Memory – 1GB DDR3
- Storage – 8GB NAND flash + SD card slot
- Video Output – HDMI 2.0, AV
- Video Codec – 4K@60 Hz video decoding 10-bit HEVC and AVS+ codec support; H.264 up to 4K 30 Hz
- Audio – HDMI, AV, coaxial S/PDIF
- Connectivity – 10/100M Ethernet, 802.11 b/g/n Wi-Fi, Bluetooth 4.0
- USB – 4x USB 2.0 host ports
John
