Informations PTZ Motion for ESCAM G02
xefil
Post by xefil »
I'm able to move my ESCAM (OnVif 2.04) using NetCat. BTW I'm not able to save Preset and call them.
Using Windows OnVif Device Manager 2.2.250 I'm able to do all.
How can I work with it?
Then, trying to enable Mdetect, it dosn't work. Into logs:
'zmtrack.pl -m 2' exited abnormally, exit status 255
If I try to execute it manually:
Tracker daemon 2 (experimental) starting at 18/05/15 23:38:24
Monitor '2' cannot move in map mode
I'm working on Debian9 with ZM1.30.4 (binary)
Thanks,
Simon
Daedilus
Re: Informations PTZ Motion for ESCAM G02
Post by Daedilus »
Hey, I'm pretty new to this forum but have the same camera that you do and have had moderate success getting things going. I have found and modified a Control script that works pretty well with this camera ESCAM G02 / IPCAMERA / C9F0SeZ0N0P2L0.
Here is a copy of the control script. Hope it helps with things.
Cheers
# ZoneMinder IPCAM2MP Control Protocol Module, $Date: 2009-11-25 09:20:00 +0000 (Wed, 04 Nov 2009) $, $Revision: 0003 $
# Copyright (C) 2001-2008  Philip Coombes
# Modified for China 2MP NetIpCam camera by Radmilo Feliox n 2015-05-05 00:03:00
# Modified for ESCAM G02 / IPCAMERA / C9F0SeZ0N0P2L0 / FW: V9.1.6.1.24-20170925 BY PETER ZARGLIS n 2018-06-09 13:45:00
# For more information/cgi-bin commands see https://www.themadhermit.net/wp-content/uploads/2013/03/FI9821W-CGI-Commands.pdf
# This module contains the implementation of the China 2MP NetIpCam camera
# control protocol.
package ZoneMinder::Control::IPCAM2MP;
use 5.006;
use strict;
use warnings;
require ZoneMinder::Base;
require ZoneMinder::Control;
# China 2MP NetIpCam Control Protocol
use Time::HiRes qw( usleep );
my $loopfactor=100000;
sub new
    my $class = shift;
    my $id = shift;
    my $logindetails = "";
    bless( $self, $class );
    srand( time() );
    return $self;
our $AUTOLOAD;
sub AUTOLOAD
    my $self = shift;
    my $name = $AUTOLOAD;
    $name =~ s/.*://;
    if ( exists($self->{$name}) )
    return( $self->{$name} );
sub open
    my $self = shift;
    $self->loadMonitor();
    use LWP::UserAgent;
#    $self->{ua}->agent( "ZoneMinder Control Agent/".ZM_VERSION );
    $self->{ua}->agent( "ZoneMinder Control Agent" );
    $self->{state} = 'open';
sub close
    my $self = shift;
    $self->{state} = 'closed';
sub sendCmd
    my $self = shift;
    my $cmd = shift;
    my $result = undef;
    if ( $res->is_success )
        $result = $res->decoded_content;
    else
    return( $result );
# Reboot camera
sub reset
    my $self = shift;
    Debug( "Camera Reset" );
    my $cmd = "cgi-bin/hi3510/sysreboot.cgi";
    $self->sendCmd( $cmd );
# Flip image on vertically
sub wake
    my $self = shift;
    Debug( "Flip on" );
    my $cmd = "cgi-bin/hi3510/param.cgi?cmd=setvdisplayattr&-flip=on";
# Flip image off vertically
sub sleep
    my $self = shift;
    Debug( "Flip off" );
    my $cmd = "cgi-bin/hi3510/param.cgi?cmd=setvdisplayattr&-flip=off";
sub moveConUp
    my $self = shift;
    my $params = shift;
    my $cmd = "cgi-bin/hi3510/param.cgi?cmd=ptzctrl&-step=0&-speed=10&-act=up";
    my $autostop = $self->getParam( $params, 'autostop', 0 );
    if ( $autostop && $self->{Monitor}->{AutoStopTimeout} )
        usleep( $self->{Monitor}->{AutoStopTimeout} );
        $self->moveStop( $params );
    else
sub moveConDown
    my $self = shift;
    my $params = shift;
    my $cmd = "cgi-bin/hi3510/param.cgi?cmd=ptzctrl&-step=0&-speed=10&-act=down";
    else
sub moveConRight
    my $self = shift;
    my $params = shift;
    Debug( "Move Right" );
    my $cmd = "cgi-bin/hi3510/param.cgi?cmd=ptzctrl&-step=0&-speed=10&-act=right";
    else
sub moveConLeft
    my $self = shift;
    my $params = shift;
    my $cmd = "cgi-bin/hi3510/param.cgi?cmd=ptzctrl&-step=0&-speed=10&-act=left";
    else
# The camera can not move diagonally, so we will implement those movements in the next 4 subroutines:
sub moveConUpLeft
    my $self = shift;
    my $params = shift;
    my $loopcount=int($self->{Monitor}->{AutoStopTimeout}/$loopfactor);
        while ( $loopcount  )
             $loopcount--;
sub moveConUpRight
   my $self = shift;
   my $params = shift;
             $loopcount--;
sub moveConDownRight
    my $self = shift;
    my $params = shift;
            $loopcount--;
sub moveConDownLeft
    my $self = shift;
    my $params = shift;
            $loopcount--;
sub moveStop
    my $self = shift;
    print("autostop\n");
    my $cmd = "cgi-bin/hi3510/param.cgi?cmd=ptzctrl&-step=0&-speed=10&-act=stop";
sub getDisplayAttr
    my $self = shift;
    my $param = shift;
    my $cmdget = "cgi-bin/hi3510/param.cgi?cmd=getvdisplayattr&-brightness";
    my $resp = $self->sendCmd( $cmdget );
    my @buffer=split(';',$resp);
    my $response=$buffer[$param];
    my @buffer=split('"',$response);
    my $response=$buffer[1];
    return ($response);
# presetHome is used to normalize the brightness/contrast/hue/saturation values
sub presetHome
    my $self = shift;
    Debug( "Home Preset" );
    my $cmd = "cgi-bin/hi3510/param.cgi?cmd=setvdisplayattr&-brightness=50&-contrast=50&-saturation=50&-hue=50";
sub presetSet
    my $self = shift;
    my $params = shift;
    Debug( "Set Preset $preset " );
    my $cmd = "cgi-bin/hi3510/preset.cgi?-act=set&-status=1&-number=$preset";
sub presetGoto
    my $self = shift;
    my $params = shift;
    my $cmd = "/cgi-bin/hi3510/preset.cgi?-act=goto&-number=$preset";
# Contrast control
sub whiteAbsIn
    my $self = shift;
    my $params = shift;
    Debug( "Contrast up" );
    my $dvalue=$self->getDisplayAttr(6);
    if ( $dvalue < 100 )
    $dvalue=$dvalue+5;
    my $cmd = "cgi-bin/hi3510/param.cgi?cmd=setvdisplayattr&-contrast=$dvalue";
# Contrast control
sub whiteAbsOut
    my $self = shift;
    my $params = shift;
    Debug( "Contrast down" );
    if ( $dvalue > 0 )
    $dvalue=$dvalue-5;
# Brightness control
sub irisAbsOpen
    my $self = shift;
    my $params = shift;
    Debug( "Brightness up" );
    my $dvalue=$self->getDisplayAttr(4);
    $dvalue=$dvalue+5;
    my $cmd = "cgi-bin/hi3510/param.cgi?cmd=setvdisplayattr&-brightness=$dvalue";
sub irisAbsClose
    my $self = shift;
    my $params = shift;
    Debug( "Brightness down" );
    if ( $dvalue > 0 )
    $dvalue=$dvalue-5;
# Saturation control
sub zoomAbsTele
    my $self = shift;
    my $params = shift;
    Debug( "Saturation up" );
    my $dvalue=$self->getDisplayAttr(5);
    $dvalue=$dvalue+5;
    my $cmd = "cgi-bin/hi3510/param.cgi?cmd=setvdisplayattr&-saturation=$dvalue";
sub zoomAbsWide
    my $self = shift;
    my $params = shift;
    Debug( "Saturation down" );
    if ( $dvalue > 0 )
    $dvalue=$dvalue-5;
# Hue control
sub focusAbsNear
    my $self = shift;
    my $params = shift;
    Debug( "Hue up" );
    my $dvalue=$self->getDisplayAttr(7);
    $dvalue=$dvalue+5;
    my $cmd = "cgi-bin/hi3510/param.cgi?cmd=setvdisplayattr&-hue=$dvalue";
# Hue control
sub focusAbsFar
    my $self = shift;
    my $params = shift;
    Debug( "Hue down" );
    if ( $dvalue > 0 )
    $dvalue=$dvalue-5;
1;
xefil
Post by xefil »
Hello Daedilus,
Thanks for sharing.
After playing around I was able to let it work succesfully.
BTW I'll try your script as well.
Thanks, Simon
