zoneminder 1.30.4 hikvision - ds-2ce16c2t-it3
zrock
Post by zrock »
does not bring me an image
Source Type ffmpeg
Source Path rtsp://admin:password@192.168.0.1//Streaming/Channels/1
and so rtsp://admin:password@192.168.0.1:554/Streaming/Channels/1
Remote Method (?) UDP multicast
Target colorspace 24 bit
Capture Width (pixels) 640
Capture Height (pixels) 480
log zoneminder
Unable to open input rtsp://admin:password@192.168.0.1//Streaming/Channels/1 due to: Operation now in progress
model camera hikvision - ds-2ce16c2t-it3
where is the error ?
timf
Re: zoneminder 1.30.4 hikvision - ds-2ce16c2t-it3
Post by timf »
I've had that same message from one of my hi k vision cameras and found the by resetting the camera it seems to go away.
I had remote method as TCP
and
rtsp://xxxx:yyyy@192.168.1.17:554/Streaming/Channels/101?transportmode=mcast&profile=Profile_1
all of the above set up by ONIV probe
zrock
Post by zrock »
Unable to open input rtsp://admin:12345@192.168.1.17:554/Streaming/Channels/101?transportmode=mcast&profile=Profile_1 due to: Connection timed out
Pedulla
Post by Pedulla »
Over at iSpy, they have a handy little chart:https://www.ispyconnect.com/man.aspx?n=Hikvision
I think you were on the write track with your previous url, less the // in the middle.
I use the tcp transport, not UDP.
However, the model you list is an analog cam. https://www.hikvision.com/en/Products/A ... 2T-IT1/IT3, so not sure how that all works.
