how do i install Zoneminder on linux mint 18.3? (need step by step instructions)
linuxcar1
Post by linuxcar1 »
so i tried a week now to install zm but with no luck.
i am new with linux and dont know how to work with it yet but zoneminder is importend for my security camera(s)
What is tried is this:
https://zoneminder.readthedocs.io/en/st ... buntu.html
But without succes.
Then i tried the some instructions from youtube video's
- https://www.youtube.com/watch?v=Spr-JD2bEbc
- https://www.youtube.com/watch?v=Fw4SQur6rbI
also no succes and my whole pc crasht and must install linux all over again. :cry:
then they told me to install this scripts
https://wiki.zoneminder.com/Shell_scrip ... 28MySQL.29
also this gives problems. (see this topic: viewtopic.php?f=37&t=27309)
i dont know what to do anymore.
i need someone that gives me step by step instructions
Re: how do i install Zoneminder on linux mint 18.3? (need step by step instructions)
Try the shell script again. There were some errors in it which were fixed over the weekend.
linuxcar1
Post by linuxcar1 »
bbunge wrote: Wed Jun 13, 2018 11:54 am Try the shell script again. There were some errors in it which were fixed over the weekend.
how do you know about the errors?
anysways, i have installed the 2 scripts and i see a Apache2 Ubuntu Default Page on http://192.168.1.100/
But i dont understand how i got zoneminder get to work...
edit: when i test of mysql is running or not (# service mysql status)
it says:
mysql.service
Loaded: masked (/dev/null; bad)
Active: inactive (dead) (Result: exit-code) since Wed 2018-06-13 12:35:13 CES
Main PID: 375 (code=exited, status=1/FAILURE)
So i have trtied some random commands:
# systemctl restart mysql
Failed to restart mysql.service: Unit mysql.service is masked.
# service mysqld start
Failed to start mysqld.service: Unit mysqld.service not found.
# sudo systemctl unmask mysql.service
Removed symlink /etc/systemd/system/mysql.service
Job for mysql.service failed because the control process exited with error code. See "systemctl status mysql.service" and "journalctl -xe" for details.
# systemctl status mysql.service
mysql.service - MySQL Community Server
Loaded: loaded (/lib/systemd/system/mysql.service; enabled; vendor preset: en
Active: activating (start-post) (Result: exit-code) since Wed 2018-06-13 18:1
Process: 28478 ExecStart=/usr/sbin/mysqld (code=exited, status=1/FAILURE)
Process: 28471 ExecStartPre=/usr/share/mysql/mysql-systemd-start pre (code=exi
Main PID: 28478 (code=exited, status=1/FAILURE); : 28479 (mysql-systemd
CGroup: /system.slice/mysql.service
└─control
├─28479 /bin/bash /usr/share/mysql/mysql-systemd-start post
└─28517 sleep 1
# sudo apt-get -f install
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following package was automatically installed and is no longer required:
mariadb-common
Use 'sudo apt autoremove' to remove it.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
3 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up mysql-server-5.7 (5.7.22-0ubuntu0.16.04.1) ...
update-alternatives: warning: forcing reinstallation of alternative /etc/mysql/mariadb.cnf because link group my.cnf is broken
update-alternatives: warning: not replacing /etc/mysql/my.cnf with a link
ERROR: Unable to start MySQL server:
2018-06-13T16:47:06.806424Z 0 [ERROR] unknown option '--NO_ENGINE_SUBSTITUTION'
2018-06-13T16:47:06.809833Z 0 [ERROR] Aborting
Please take a look at https://wiki.debian.org/Teams/MySQL/FAQ for tips on fixing common upgrade issues.
Once the problem is resolved, run apt-get --fix-broken install to retry.
dpkg: error processing package mysql-server-5.7 (--configure):
subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of mysql-server:
mysql-server depends on mysql-server-5.7; however:
Package mysql-server-5.7 is not configured yet.
dpkg: error processing package mysql-server (--configure):
dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
Setting up zoneminder (1.30.4-xenial1) ...
mysql.service couldn't start.
dpkg: error processing package zoneminder (--configure):
Errors were encountered while processing:
mysql-server-5.7
mysql-server
zoneminder
E: Sub-process /usr/bin/dpkg returned an error code (1)
[/quote]
