Question about instant event notifications
Posted: Tue Jun 19, 2018 10:12 am
Greetings,
This is my first post, and I've just begun experimenting with ZoneMinder to replace a homegrown system (based on Motion, i.e. "motion-project", and some custom tooling) because it can't deal with all of the moving shadows at my new house.
I've been reading through the forums and Google (as well as the docs) and am sort of confused... am I correct that there's no built-in way to trigger external actions immediately when an event occurs?
At first I thought/read that filters could do it, but that doesn't seem to be the case. I was really confused by the documentation around the "Run in background" option; apparently this seems to be from the web UI's perspective (run the filter on a regular basis instead of when you click the button) as opposed to what I originally thought, the event's perspective (run on a regular basis, instead of every time a new event occurs).
I've found pliablepixels/zmeventserver but I don't really understand why I'd use that; it's still just polling the shared memory on a regular - albeit short - interval.
Am I correct that there's no way to just automatically hook in some external action/command every time an event happens, immediately when the event happens, either built-in or some widely-used "addon" or "plugin"?
Thanks,
Jason
Thanks,
Jason
