Page 1 of 1
Linux Mint 19 1.31.44~20180625162520
Posted: Mon Jul 02, 2018 3:22 am
by DVB Hardware
Seems to be working fine but I only have 1 camera
I did have a problem using bbunge install script for some reason that I never did before.
bbunge thank you for the script it has been a time saver just testing an fiddling around
I had a problem with apt -y install for the lamp install, changed it to apt install and added sudo for executable lines.
With the -y and and no sudo even though I was logged in as root it would die in a second
I did split up the script into 2 files, server install and zoneminder install for storage-areas ppa
just easier for me since I wipe the test box sometimes due to some point of sale testing.
I use Mint because I don't have time to remember a lot of the commands on a ubuntu server with putty
Jimmy
Re: Linux Mint 19 1.31.44~20180625162520
Posted: Tue Jul 03, 2018 12:12 pm
by bbunge
Mint adds a bunch of stuff you do not need. May I recommend you try Lubuntu 18.04 and install the minimal version.
And, I have not tested the scripts with development versions of Zoneminder.
Posted: Tue Jul 03, 2018 3:40 pm
by DVB Hardware
Thanks, Forgot about that distro, I have Mint on 3 machines for the kids, mine I stripped a lot of the programs out.
Jimmy
