Multiple server setup
gsaindon
Post by gsaindon »
I have a multiple server setup, one server for database and shared storage and 6 servers for the cameras. In version 1.30 it was possible to view any events that had been saved by any server by login on to any of them.
In 1.31.44, I cannot view the events saved by another server, the message "the video could not be loaded appears". I thought it was a permission problem but if I log in to the server that saved the event and view an event, it then becomes viewable by the other servers.
Any idea?
Thanks for the help.
gsaindon
Re: Multiple server setup
Post by gsaindon »
I just discovered that if I disable user authentication it works fine.
You might need to turn on AUTH_RELAY and AUTH_HASH_LOGINS
gsaindon
Post by gsaindon »
Problem solved.
Thanks,
