Page 1 of 1
Multiple server setup
Posted: Fri Jul 06, 2018 12:23 pm
by gsaindon
I have a multiple server setup, one server for database and shared storage and 6 servers for the cameras. In version 1.30 it was possible to view any events that had been saved by any server by login on to any of them.
In 1.31.44, I cannot view the events saved by another server, the message "the video could not be loaded appears". I thought it was a permission problem but if I log in to the server that saved the event and view an event, it then becomes viewable by the other servers.
Any idea?
Thanks for the help.
Re: Multiple server setup
Posted: Fri Jul 06, 2018 2:25 pm
by gsaindon
I just discovered that if I disable user authentication it works fine.
Posted: Wed Jul 11, 2018 12:10 pm
by iconnor
You might need to turn on AUTH_RELAY and AUTH_HASH_LOGINS
Posted: Fri Jul 13, 2018 12:03 pm
by gsaindon
Problem solved.
Thanks,
