zmNinja: Error retrieving detailed frame API
Posted: Fri Jul 13, 2018 7:41 pm
Recent issue encountered with zmNinja on Windows and Android accessing zoneminder-h264 on FreeBSD
zmNinja is unable to playback event as I receive "could not retrieve frame details"
getVersion.json:
monitors.json:
getVersion.json:
{"version":"1.30.2","apiversion":"1.0"}
{"monitors":[{"Monitor":{"Id":"2","Name":"Front Door","ServerId":"0","Type":"Ffmpeg","Function":"Modect","Enabled":"1","LinkedMonitors":"2","Triggers":"","Device":"\/dev\/video0","Channel":"0","Format":"255","V4LMultiBuffer":false,"V4LCapturesPerFrame":"1","Protocol":"rtsp","Method":"rtpRtsp","Host":"192.168.1.101","Port":"554","SubPath":"","Path":"rtsp:\/\/192.168.1.151:554\/cam\/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif","Options":"","User":"","Pass":"","Width":"1920","Height":"1080","Colours":"4","Palette":"0","Orientation":"0","Deinterlacing":"0","SaveJPEGs":"3","VideoWriter":"2","EncoderParameters":"","RecordAudio":"0","RTSPDescribe":false,"Brightness":"-1","Contrast":"-1","Hue":"-1","Colour":"-1","EventPrefix":"Event-","LabelFormat":"%m\/%d\/%y %H:%M:%S","LabelX":"0","LabelY":"0","LabelSize":"2","ImageBufferCount":"400","WarmupCount":"35","PreEventCount":"400","PostEventCount":"260","StreamReplayBuffer":"1000","AlarmFrameCount":"4","SectionLength":"600","FrameSkip":"0","MotionFrameSkip":"0","AnalysisFPS":"0.00","AnalysisUpdateDelay":"0","MaxFPS":"0.00","AlarmMaxFPS":"0.00","FPSReportInterval":"1000","RefBlendPerc":"6","AlarmRefBlendPerc":"3","Controllable":"0","ControlId":"0","ControlDevice":null,"ControlAddress":null,"AutoStopTimeout":null,"TrackMotion":"0","TrackDelay":"0","ReturnLocation":"-1","ReturnDelay":"0","DefaultView":"Events","DefaultRate":"100","DefaultScale":"25","SignalCheckColour":"#0000c0","WebColour":"red","Exif":true,"Sequence":"1"}}]}
zmNinja version:1.3.008D (desktop)
ZoneMinder version:1.30.2
Jul 13, 2018 02:05:30 PM INFO >>>Starting checkAllEvents interval...
Jul 13, 2018 02:05:29 PM INFO Error retrieving detailed frame API {"data":{"success":false,"data":{"name":"An Internal Error Has Occurred.","message":"An Internal Error Has Occurred.","url":"/zoneminder/api/events/51115.json?p=events%2F51115.json","exception":{"class":"PDOException","code":"42000","message":"SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'fileExists' at line 1"}}},"status":500,"config":{"method":"GET","transformRequest":[null],"transformResponse":[null],"url":"https://my.server/zoneminder/api/events/51115.json","headers":{"Accept":"application/json, text/plain, */*"}},"statusText":"Internal Server Error"}
Jul 13, 2018 02:05:28 PM INFO *** Constructed API for detailed events: https://my.server/zoneminder/api/events/51115.json
Jul 13, 2018 02:05:28 PM INFO Using stream mode single
Jul 13, 2018 02:05:28 PM INFO ZM_EVENT_IMAGE_DIGITS is already configured for 5
Jul 13, 2018 02:05:21 PM INFO *** PROGRESS WAS NOT CALLED
Jul 13, 2018 02:05:21 PM INFO Returning pre-loaded list of 1 monitors
Jul 13, 2018 02:05:14 PM INFO MonitorCtrl:Stopping network pull...
Jul 13, 2018 02:05:09 PM INFO configurePTZ 2 is not PTZ controllable
Jul 13, 2018 02:05:09 PM INFO Using stream mode single
Jul 13, 2018 02:05:09 PM INFO Monitor Orientation is: undefined
Jul 13, 2018 02:05:04 PM INFO Returning pre-loaded list of 1 monitors
Jul 13, 2018 01:59:28 PM INFO Stream authentication construction: &user=Zorak<password removed>
Jul 13, 2018 01:59:28 PM INFO DataModel: Found simple stream auth mode (user=)
Jul 13, 2018 01:59:28 PM INFO DataModel: Did not find a stream auth key, looking for user=
Jul 13, 2018 01:59:28 PM INFO ZM has recaptcha disabled - good
Jul 13, 2018 01:59:28 PM INFO zmAutologin successfully logged into Zoneminder
Jul 13, 2018 01:59:28 PM INFO Checking if reCaptcha is enabled in ZM...
Jul 13, 2018 01:59:28 PM INFO zmAutologin called
Jul 13, 2018 01:29:30 PM INFO *** PROGRESS WAS NOT CALLED
Jul 13, 2018 01:29:29 PM INFO multi server list loaded{"servers":[]}
Jul 13, 2018 01:29:29 PM INFO DataModel: Found simple stream auth mode (user=)
Jul 13, 2018 01:29:29 PM INFO DataModel: Did not find a stream auth key, looking for user=
Jul 13, 2018 01:29:29 PM INFO Monitor load was successful, loaded 1 monitors
Jul 13, 2018 01:29:29 PM INFO Now that we have monitors, lets get AuthKey...
Jul 13, 2018 01:29:29 PM INFO ZM_MIN_STREAMING_PORT not supported
Jul 13, 2018 01:29:29 PM INFO ZM_EVENT_IMAGE_DIGITS is 5
Jul 13, 2018 01:29:29 PM INFO Checking value of ZM_MIN_STREAMING_PORT for the first time
Jul 13, 2018 01:29:29 PM INFO getMonitors:Loading all monitors
Jul 13, 2018 01:29:29 PM INFO No Event Server present. Not initializing
Jul 13, 2018 01:29:29 PM INFO First invocation of TimeZone, asking server
Jul 13, 2018 01:29:29 PM INFO Got API version: 1.30.2
Jul 13, 2018 01:29:29 PM INFO Stream authentication construction: undefined
Jul 13, 2018 01:29:29 PM INFO Deferring auth key, as monitorId unknown
Jul 13, 2018 01:29:29 PM INFO zmAutologin successfully logged into Zoneminder
Jul 13, 2018 01:29:29 PM INFO ZM has recaptcha disabled - good
Jul 13, 2018 01:29:28 PM INFO Checking if reCaptcha is enabled in ZM...
Jul 13, 2018 01:29:28 PM INFO zmAutologin called
Jul 13, 2018 01:29:28 PM INFO https://my.server/zoneminder=>Logging out of any existing ZM sessions...
Jul 13, 2018 01:29:28 PM INFO Cancelling zmAutologin timer
Jul 13, 2018 01:29:28 PM INFO not checking for touchID
Jul 13, 2018 01:29:28 PM INFO User credentials are provided
Jul 13, 2018 01:29:27 PM INFO Entering Portal Main
Jul 13, 2018 01:29:27 PM INFO Inside init-complete in app.js: All init over, going to portal login
Jul 13, 2018 01:29:27 PM INFO DataModel init retrieved store loginData
Jul 13, 2018 01:29:27 PM INFO SlowDelay is: false
Jul 13, 2018 01:29:27 PM INFO Setting DataModel init bandwidth to: highbw
Jul 13, 2018 01:29:27 PM INFO user profile encrypted, decoding...
Jul 13, 2018 01:29:27 PM INFO Setting up pause and resume handler AFTER language is loaded...
Jul 13, 2018 01:29:27 PM INFO Setting up POST LOGIN timer
Jul 13, 2018 01:29:27 PM INFO Checking for news updates
Jul 13, 2018 01:29:27 PM INFO Checking for new version updates...
Jul 13, 2018 01:29:27 PM INFO ZMData init: checking for stored variables & setting up log file
Jul 13, 2018 01:29:27 PM INFO Language file loaded, continuing with rest
Jul 13, 2018 01:29:27 PM DEBUG last state=app.moment param=undefined
Jul 13, 2018 01:29:27 PM DEBUG isFirstUse returned: false
Jul 13, 2018 01:29:27 PM INFO >>>>Language to be used:en
Jul 13, 2018 01:29:27 PM INFO Device Language is:en
Jul 13, 2018 01:29:27 PM INFO No language set, switching to en
Jul 13, 2018 01:29:27 PM INFO Retrieving language before init is called...
Jul 13, 2018 01:29:27 PM INFO Enabling native transitions...
Jul 13, 2018 01:29:27 PM INFO >>>>No data to import....
Jul 13, 2018 01:29:27 PM INFO localforage driver for storage:asyncStorage
Jul 13, 2018 01:29:27 PM DEBUG configureStorageDB:test get/set worked, this driver is ok...
Jul 13, 2018 01:29:27 PM DEBUG configureStorageDB:Making sure this storage driver works...
Jul 13, 2018 01:29:27 PM INFO configureStorageDB:localforage driver for storage:asyncStorage
Jul 13, 2018 01:29:27 PM DEBUG configureStorageDB: trying order:["asyncStorage","localStorageWrapper"]
Jul 13, 2018 01:29:27 PM DEBUG Inside configureStorageDB
Jul 13, 2018 01:29:27 PM INFO You are running on desktop
Jul 13, 2018 01:29:27 PM INFO Device is ready
