H264 passtrough "ghosting/smearing"
Posted: Sun Jul 29, 2018 1:20 pm
Running v1.31.44.
Using "zoneminder-master" on Ubuntu 16.04.5 LTS.
I´m having problem with ghosting/smearing/pixelation.
I´ve uploaded a sample/event with this happening sample.
You can see that at sometimes the contour of the guy/me in the picture is blending into the background.
Also, the face gets very blurry.
("Untouched" version of the event is available here).
Cameras:
4x Escam QD300 (using the settings below).
General >>
Server: None
Storage Area: Default
Source Type: Ffmpeg
Function: Modect
Enabled: yes
Linked Monitors:
Groups:
Analysis FPS:
Maximum FPS (?): 15.00 (my cameras are set to 12 fps in camera settings)
Alarm Maximum FPS (?): 15.00(my cameras are set to 12 fps in camera settings)
Reference Image Blend %ge: 6.25% (Indoor)
Alarm Reference Image Blend %ge: 6.25%
Triggers None available
Source >>
Source Path: rtsp://192.168.254.32:554/user=admin&password=&channel=1&stream=0.sdp
Method (?) : TCP
Options (?):
Target colorspace: 32 bit colour
Capture Width (pixels): 1280
Capture Height (pixels): 720
Preserve Aspect Ratio: no
Orientation: Normal
Deinterlacing: Disabled
Storage >>
Save JPEGs: Frames + Analysis images (if available)
Video Writer: H264 Camera Passtrough
Optional Encoder Parameters:
# Lines beginning with # are a comment
# For changing quality, use the crf option
# 1 is best, 51 is worst quality
#crf=1
Whether to store the audio stream when saving an event.: no
Buffers >>
Image Buffer Size (frames) : 48
Warmup Frames: 0
Pre Event Image Count: 24
Post Event Image Count: 24
Stream Replay Image Buffer: 0
Alarm Frame Count: 1
Camera settings:
Any ideas?
Cameras:
General >>
Server: None
Source Type: Ffmpeg
Function: Modect
Enabled: yes
Linked Monitors:
Groups:
Analysis FPS:
Source >>
Method (?) : TCP
Options (?):
Orientation: Normal
Storage >>
#crf=1
Buffers >>
Warmup Frames: 0
Camera settings:
Any ideas?
