I was forced down the upgrade path after the Gentoo ebuild of 1.30.4 started building ZMC and a few components that segfaulted. I failed to fix that and cloned the git repository and scratch built.
The build went ok. Lacked a couple of Perl bits but sorted those
emerge -av dev-perl/File-Slurp
emerge -av dev-perl/Number-Bytes-Human
Point of this post is that the API wouldn't work and it was an authentication problem. However, I don't have ZM authentication on. ZM was fine, ZMNinja was not.
It was testing credentials without checking if ZM Auth was on first. There seems to have been a regression of this update - https://github.com/ZoneMinder/zoneminde ... 1008/files . I copied over the 1.30.4 AppController.php and that sorted it.
Hopefully this will help someone.
