zmrepo has newer versions of ZM 1.31 stretch builds only for arm devices. Is there another place for amd64 deb packages?
I´m really want to try 1.31.45 because of crazy ffmpeg converts in 1.30.4 .
Thanks.
Debian stretch amd64
Re: Debian stretch amd64
Last I knew 1.30.4 worked well in Debian without any "converts." Of course you could switch to Ubuntu....
I've been lazy about building packages for debian. I'll fire one off today.
Thanks for building and uploading.
But a stupid question: How to set /etc/apt/sources.list ? deb https://zmrepo.zoneminder.com/debian stretch main ?
I´ve found out that "deb https://zmrepo.zoneminder.com/debian/master stretch/" should work. Will try next days. Thank you.
Question: What is wrong with the ffmpeg in Debian 9.5? I have one of my test machines with a fresh install of 9.5 and ZM 1.30.4 running an IP camera on ffmpeg with no issues!
I have 1.31.45 up and running. CPU load looks good.
Are there some issues with the monitor frame rates ? I say 5, i got 1.9 frames. I say 10, i got 7.4. I say 15 i got 10. All with slow motion live view.
If i say the default 30 i got my real 10 frames from source.
After 24 hours service i got 17000!!!! log entries
Hi DerGraf,
Can you tell me how you upgraded to this version?
I'm running v1.30.4 and would like to upgrade to get the audio functionality working, but, I can't work out how to do that (I'm using Debian Stretch also)
Thanks,
Luke
Thanks,
Luke
I've managed to move to 1.31 now, but, I've got some issues with the cameras displaying (not displaying anything... )
