If you delete the "Default" storage, it is still an option, and becomes the default choice, in the monitor settings.
Events are still being recorded in the location you specify, but the playback of events is changed to the original Default even though it should no longer be an option.
You have to specify your choice of storage whenever you edit the monitors, otherwise it breaks playback.
If you try to put BACK the "Default" storage in Options -> Storage, you get TWO "Default" choices in the monitors.
