Page 1 of 1
apt problem with zmrepo
Posted: Sun Sep 02, 2018 11:49 am
by DerGraf
I used ZM 1.31.45 from zmrepo for Debian Strech amd64. Thanks again for building.
In my /etc/apt/sources.list is the deb-multimedia.org as well. I need that for different packages.
Now on "apt update" and "apt upgrade" ZM will downgrade to 1.30.4 from deb-multimedia.org. So i cant upgrade my system. I think it is the result of that warning:
root@debian:~# apt-get update
Ign:8 https://zmrepo.zoneminder.com/debian/master stretch/ InRelease
OK:9 https://zmrepo.zoneminder.com/debian/master stretch/ Release
Ign:11 https://zmrepo.zoneminder.com/debian/master stretch/ Release.gpg
W: The repository 'https://zmrepo.zoneminder.com/debian/master stretch/ Release' is not signed.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Importing of the GPG signature public key has done.
Need some help. Thanks.
Re: apt problem with zmrepo
Posted: Sun Sep 02, 2018 12:02 pm
by bbunge
You should be able to hold Zoneminder. I do that in Ubuntu.
Posted: Sun Sep 02, 2018 12:13 pm
by DerGraf
bbunge wrote: Sun Sep 02, 2018 12:02 pm You should be able to hold Zoneminder. I do that in Ubuntu.
Is there a command for holding a package?
Edit: apt command for holding zoneminder is "apt-mark hold zoneminder". More than easy :oops:
