Can't Playback Video from Hour 00
Posted: Wed Sep 12, 2018 3:06 pm
I'm running ZM 1.31.45
I've done a lot of looking but can't find the fix for this... The entire installation is working perfectly fine except for a playback issue.
When I attempt to playback events that are in the hour "00", they won't play. On some browsers it just loads forever. On others, I get a file not found message.
50547 Event- 50547 Back Lot 5 Continuous 09/12 00:40:00 until 09/12 00:50:00 00:10:00 2997 0 0 0 0 BigStorage
50555 Event- 50555 Back Lot 5 Continuous 09/12 00:50:00 until 09/12 01:00:00 00:10:00 2998 0 0 0 0 BigStorage
50568 Event- 50568 Back Lot 5 Continuous 09/12 01:00:00 until 09/12 01:10:00 00:10:00 2997 0 0 0 0 BigStorage
50577 Event- 50577 Back Lot 5 Continuous 09/12 01:10:00 until 09/12 01:20:00 00:10:00 2996 0 0 0 0 BigStorage
For example, Event 50547 and 50555 have the problem - but the next two work fine. Only the six events that fall in the hour beginning with "00" have the problem. And they have it every single day since we installed.
Does anyone know the likely super simple solution to fix this?
Bill
Bill
