Page 1 of 1
Upload won't work
Posted: Wed Sep 19, 2018 4:54 pm
by sagitt
I'm not able to upload on my sftp server
works very well with olter version
i found this error in logs: Unknown function call Filter->AutoUpload from /usr/share/zoneminder/www/index.php:254
finter are correctly setted and server works.
Re: Upload won't work
Posted: Thu Sep 20, 2018 5:38 pm
by iconnor
Just pushed the fix to master. Packages will build in a bit.
Posted: Fri Sep 21, 2018 5:25 pm
by sagitt
iconnor wrote: ↑Thu Sep 20, 2018 5:38 pm
upgraded but still not working (upload)
anyway
i've some other problems
you can see the post "more problems"
viewtopic.php?f=38&t=27535
and zmtrigger works very bad.... sometimes works fine, others stop my record after 6-10 seconds...
my trigger interface works very well with older version.
the way to restore it to working after the problem is terminate zmtrigger.pl and restart system or reinstall zoneminder.
Posted: Fri Sep 28, 2018 4:31 pm
by sagitt
Still not working...........
