Since upgrading from 1.31.47 event playback does not work anymore. I get an error "Event not found". Here is what appears in the logfile:
Sep 19 14:50:40 zoneminderview web_php[7427]: ERR [getCmdResponse stream error: Socket /var/run/zm/zms-984136s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/lat ... window-etc for more information. - checkStreamForErrors()]
Thanks,
Event playback
Re: Event playback
If I go through "Montage review" I am able to playback the events.
Re: Event playback
Same problem.
Zoneminder 1.32.0~20180919200623-bionic upgraded from 1.31.**
Log after playback try:
2018-09-20 09:20:43 web_js 1279 ERR
getCmdResponse stream error: Socket /var/run/zm/zms-240343s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors() ?view=event
2018-09-20 09:20:43 web_php 1279 ERR
Socket /var/run/zm/zms-240343s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. /usr/share/zoneminder/www/includes/functions.php 2042
TypeError: null is not an object (evaluating '$('imageFeed').getElement') http://10.0.2.64/zm/cache/skins_classic_views_js_event-base-1537401983.js
Re: Event playback
Fixed in 1.32.0~20180920110220-bionic.
Thank you!
Thank you!
