I am running 1.32.0-1.53.
I am wondering if there is any expectation that audio should work on the live-stream to an RTSP feed?
I have some cameras coming with integrated MIC, and I am experimenting to see how we can get audio working for baby-monitor use case. To test, I've set up VLC to stream my webcam and MIC via RTSP, and I can load that stream in VLC and hear the audio. I load the same rtsp stream as a zoneminder ffmpeg monitor with UDP method, enable h264 camera passthrough video writer, and enable storing audio stream. I get audio in recorded events, but not live stream.
Is this expected for the live stream? I've found conflicting messages in different forums and other sources about whether audio on live stream was expected to land in 1.32, and so I'm not sure if I've got something wrong with my setup or my test, or if this is a non-existent feature.
