Privacy Error
jmynheir
Privacy Error
Post by jmynheir »
I am getting this page about every 4 seconds from Montage View in Chrome
If I connect by direct IP https://192.168.0.2/zm Everything is fine and I only get this on first load
If I connect by looping through my router https://[myserver.com]/zm I will get this every 4 seconds in Montage View
This was the case in 1.32.0, however it seemed corrected in 1.32.1
Now that I upgraded to 1.32.2-1 I am having this issue again
Re: Privacy Error
Not a Zoneminder problem. You set up Apache with a self signed SSL certificate. It is your server. Do you trust yourself? Just accept the certificate, permanently.
jmynheir
Re: Privacy Error
Post by jmynheir »
I accept the cert but something about the way the pages reload cause it to pop up the privacy error every 4 seconds or so and you have to go to advanced-proceed. I can use Firefox and set permanent exception, but Chrome won't. I'm just saying that this happened in 1.32.0, not 1.32.1, but now again it's happening in 1.32.2
