debug alarm zone
macbeth78
debug alarm zone
Post by macbeth78 »
Is there a feature to highlight a zone that triggered an alarm ? I'm trying to debug my configuration but i don't really understand which zones triggered the event.
Re: debug alarm zone
each event created has a "Notes" that when an event is made by a zone activating, that zone's name is in the "Notes" field.
open the Event viewer and where the events are listed...click in the column "Cause" and select a value on one of the events and the Notes view window will pop open. There you find out the name of the zone which activated that event.
sphillips
Post by sphillips »
even better for debugging is the stats page found under events->max score->stats
it should show you which zone was triggered and more, check to see if options->Logging->RECORD_EVENT_STATS is enabled for it to work
