Page 1 of 1
storage feature in 1.32.X
Posted: Fri Oct 26, 2018 3:01 am
by MoOz
Zoneminder 1.32.X
adding a second drive
is there documentation for it
what is the best way
Re: storage feature in 1.32.X
Posted: Fri Oct 26, 2018 8:50 am
by Nocifer
Do you mean a second drive as in extra storage, or a second drive as in running a separate ZM or database instance from it?
If the former, then all you need to do is mount that drive somewhere and then go to Options -> Storage -> ADD NEW STORAGE and fill in the needed info. Then you can use the new storage by assigning it in a monitor's settings page, in General (first tab) -> Storage Area (third row from the top).
If the latter, a good starting point would be here:
https://zoneminder.readthedocs.io/en/st ... erver.html
