In adding a new monitor, I get the following error. This seems to indicate that Port is not being defined, but it's correctly entered in the RSTP string and there are no fields in the dialog where I can add it explicitly. How do I fix? Thanks. Eric
SQL-ERR 'SQLSTATE[23000]: Integrity constraint violation: 1048 Column 'Port' cannot be null', statement was 'INSERT INTO Monitors SET `LinkedMonitors` = NULL, `Name` = 'Barn-L', `ServerId` = NULL, `StorageId` = '1', `Type` = 'Ffmpeg', `Function` = 'Mocord', Enabled = 1, `RefBlendPerc` = '6', `AlarmRefBlendPerc` = '6', `AnalysisFPSLimit` = NULL, `MaxFPS` = '30', `AlarmMaxFPS` = '30', `Triggers` = '', `Device` = '/dev/video0', `Channel` = '0', `Format` = '255', `Palette` = '0', `V4LMultiBuffer` = NULL, `V4LCapturesPerFrame` = '1', `Protocol` = NULL, `Host` = NULL, `Port` = NULL, Method = 'rtpRtsp', `Options` = NULL, `Path` = 'rtsp://admin:passwd@192.168.1.92:21002/videoMain', `User` = NULL, `Pass` = NULL, `Colours` = '4', `Width` = '1280', `Height` = '720', `Orientation` = '0', `Deinterlacing` = '0', `SaveJPEGs` = '0', `VideoWriter` = '1', `EncoderParameters` = '# Lines beginning with # are a comment \r\n# For changing quality, use the crf option\r\n# 1 is best, 51 is worst quality\r\n#crf=23', RecordAudio = 0, RTSPDescribe = 0, `LabelFormat` = '%N - %d/%m/%y %H:%M:%S', `LabelX` = '0', `LabelY` = '0', `LabelSize` = '1', `ImageBufferCount` = '20', `WarmupCount` = '0', `PreEventCount` = '0', `PostEventCount` = '5', `StreamReplayBuffer` = '0', `AlarmFrameCount` = '1', `EventPrefix` = 'Event-', `SectionLength` = '600', `FrameSkip` = '0', `MotionFrameSkip` = '0', `AnalysisUpdateDelay` = '0', `FPSReportInterval` = '100', `DefaultView` = 'Events', `DefaultRate` = '100', `DefaultScale` = '100', `WebColour` = 'red', Exif = 0, `SignalCheckPoints` = '10', `SignalCheckColour` = '#0000c0', `ControlId` = '12', `ControlDevice` = '', `ControlAddress` = '', `AutoStopTimeout` = NULL, `TrackDelay` = NULL, `ReturnLocation` = '-1', `ReturnDelay` = NULL, Sequence = 1' params:
Can't add monitor
Re: Can't add monitor
Did you upgrade from 1.30.4?
We also need the Linux distro and version along with the instructions you used to install or upgrade.
I did a fresh install on Ubuntu Server 18.04.1 (onto which I had installed a LAMP stack). I followed the "easy way" script for the distro.
Appreciate any help. Thanks
Eric
Eric
I discovered the problem... can't add a monitor from Foscam F19821W Preset. If I just enter all the data from scratch, then it works. But, not by editing starting from the preset.
Eric
Eric
