"No Frame found for event" when using bulk frames
camboi
Post by camboi »
I made quick fix
views/image.php
115       $Frame = Frame::find_one(array('EventId'=>$_REQUEST['eid'], 'FrameId'=>$_REQUEST['fid']));
116       if ( ! $Frame ) {
117         $previousBulkFrame = dbFetchOne(
118           'SELECT * FROM Frames WHERE EventId=? AND FrameId*100 < ? ORDER BY FrameID DESC LIMIT 1',
119           NULL, array($_REQUEST['eid'], $_REQUEST['fid'])
120         );
121         $nextBulkFrame = dbFetchOne(
122           'SELECT * FROM Frames WHERE EventId=? AND FrameId*100 > ? ORDER BY FrameID ASC LIMIT 1',
123           NULL, array($_REQUEST['eid'], $_REQUEST['fid'])
124         );
125         if ( $previousBulkFrame and $nextBulkFrame ) {
126           $Frame = new Frame($previousBulkFrame);
127           $Frame->FrameId($_REQUEST['fid']);
128
129           $percentage = ($Frame->FrameId() - $previousBulkFrame['FrameId']) / ($nextBulkFrame['FrameId'] - $previousBulkFrame['FrameId']);
130
131           $Frame->Delta($previousBulkFrame['Delta'] + floor( 100* ( $nextBulkFrame['Delta'] - $previousBulkFrame['Delta'] ) * $percentage )/100);
132 Logger::Debug("Got virtual frame from Bulk Frames previous delta: " . $previousBulkFrame['Delta'] . " + nextdelta:" . $nextBulkFrame['Delta'] . ' - ' . $previousBulkFrame    ['Delta'] . ' * ' . $percentage );
133         } else {
134           Fatal('No Frame found for event('.$_REQUEST['eid'].') and frame id('.$_REQUEST['fid'].')');
135         }
136       }
137
138       # MYFIX1
139       $bulkFrame = (float)$Frame->FrameId() / 100;
140       $parts = explode('.', (string)$bulkFrame);
141       $frameIndex = $parts[1];
142       $bulkFrame = floor($bulkFrame);
143       $converted_frameId = $bulkFrame + $frameIndex;
144       #Warning($converted_frameId);
145
146       // Frame can be non-existent.  We have Bulk frames.  So now we should try to load the bulk frame
147       $path = $Event->Path().'/'.sprintf('%0'.ZM_EVENT_IMAGE_DIGITS.'d',$converted_frameId).'-'.$show.'.jpg';
camboi
Re: "No Frame found for event" when using bulk frames
Post by camboi »
Is it something useful or am i just dumb and doing weird shit?
I'm confused
